- Dec 15, 2018
- 2,922
Yes, but they're the same chemistry and this thread is about paralleling 2 different chemistries with different voltage ranges.
point taken but still a very interesting videoYes, but they're the same chemistry and this thread is about paralleling 2 different chemistries with different voltage ranges.
... I wouldn't mix them because IMO it makes no sense unless it's an emergency or you're a researcher. Batteries are all about balancing, you balance them in parallel, balance voltages, balance packs in a battery, the BMS balances, your cables are all the same section per segment so to balance.Any more updates on mixing the chemistries?
Agreed as my main Battery consists now of all 18650 cells which are all 2600mAh LG and Samsung 3x14s80p LG and 1x14s80p Samsung.If somebody has a valid reason to mix chemistries, a part from emergency or research, I'd be glad to learn something new!
Been running for a few months with 14s Li-Ion and 16s LFP in parallel now, it's working quite well for me with no issues. They act like their own battery powering their own load, that just happens to be working next to another battery. Uneven load distribution as discussed earlier, each bank takes different portions of the load depending on a variety of factors. So i guess I don't have specific updates, just general observations, I don't do any data logging or anything like that.Any more updates on mixing the chemistries?
All my cells are still balanced within their separate banks, within 5-20mv, both the LFP and Li-Ion.Batteries are all about balancing, you balance them in parallel, balance voltages, balance packs in a battery, the BMS balances
"Valid" is relative, my reason is that I got a great deal on 2.5kwh of LFP cells locally that I couldn't pass up, and I can always break off this pack for a different use later. Maybe that's not a good enough reason for others, I would understand. I will likely be pulling off the LFP pack for the winter anyway: my main 14s Li-Ion powerwall is the one into which i've built heating and insulation to survive outdoor storage during the winter, and the LFP pack does not have that, so in all likelihood I'll just be storing during the cold snap.If somebody has a valid reason to mix chemistries, a part from emergency or research, I'd be glad to learn something new!
Uhm, I didn't do any calculations but I think the life of the batteries will be reduced. If unbalanced batteries lasted longer then producers would start making them unbalanced.... which will increase cycle life in the long run.
Ops, I'm very sorry if my post didn't seem polite I'm usually very diplomatic, you should know! It wasn't meant to be a negative critique, only a "prove me there's an advantage" sort of message. Sorry if I was a bit too direct, but again, I'd say by logic that this setup possibly reduces battery's life.Here's a question, which I don't mean as an attack at all,
But, my two packs are never at different voltages. So this doesn't happen, no current transfer from the higher voltage pack to the lower voltage pack, no extra charge/discharge cycles because of it.The unbalanced battery pack, where for unbalanced in this case I mainly refer to very different charge/discharge curves, will naturally move current from the higher voltage pack towards the lower voltage pack to balance different voltages; I'm not saying when this happens only that it does happen. This process is the same as applying a load to the higher voltage battery (so discharging it); on the other side, the battery with the lower voltage is receiving current which is equivalent to a charge.
The batteries aren't unbalancedIf unbalanced batteries lasted longer then producers would start making them unbalanced.
I'll read all the thread againBut, my two packs are never at different voltages. So this doesn't happen, no current transfer from the higher voltage pack to the lower voltage pack, no extra charge/discharge cycles because of it.
Uhm, they are unbalanced. When they are unbalanced you will see current movements between the two of them, because they are balancing each other. If they were balanced you wouldn't see any current movement. I read the whole thread again. You describe the effects of the "balancing the unbalanced process" multiple times, quoting:...
Or any BMS, really, each chemistry would need it's own BMS. Let's call that downside #1.From my perspective, I could not mix these chemistries with a single Batrium BMS
As a result, I have the max voltage at 54.8v. @J_Mack58 charges to 55v. 3.92v per Li-ion cell. Mostly it's a downside, because that's a decent amount of capacity above 3.92v that isn't getting used. You could look at it as an upside, if you'd like, if your battery is big enough, because reduced DoD = more cycles. Depends on your system preferences.I think that they will maintain the same voltage when in parallel and so you can't use the entire capacity range of Li-Ion when yoked to LifePo4.
True. And if the load isn't large, there is no current movement. During average house loads, or when small loads are removed, there is no current movement. In my case, this rarely happens. And if it does happen, it levels off to zero after a short time. It's not a constant behavior that's always present.Uhm, they are unbalanced. When they are unbalanced you will see current movements between the two of them, because they are balancing each other. If they were balanced you wouldn't see any current movement. I read the whole thread again. You describe the effects of the "balancing the unbalanced process" multiple times, quoting:
"Here's a unique observation: I turned off the bike charger, as well as my house loads. When I checked the voltage, I was surprised to see that there was once again about 3-4 amps moving from 14s to 16s. Like when I first connected the two batteries, this lasted for only about 10ish minutes, until the transfer dropped to zero."
"when either the load or the charge current is removed, both batteries will attempt to return to resting voltage. Because the discharge curves are different between the two chemistries, the amount of movement to return to their resting voltage is different. And that's when you see unnecessary current movement between the packs. It's proportional to the amount of current that was being charged or discharge just previously"
"This means for an application with lots of significant charging or loads that start and stop suddenly, you will indeed see a lot of unnecessary current movement that stresses the cells unnecessarily"
In any case, I think this is a very good experiment and I appreciate the effort in analysing what happens and sharing the results plus the measurements.
Don't know for sure yet, however I am waiting on @ddalfons research on this as he was working on doing a test on that combo.Is there something else I need to keep an eye out for?
1/4 of that went over my head. lolDon't know for sure yet, however I am waiting on @ddalfons research on this as he was working on doing a test on that combo.
I also have a bunch of (96 or so) 40Ah CALB 3.2V cells. Once back from Vacation/Holiday, I will put this on my list to build a test project.
I have been dying to use my stock of CD74HC4067 16 to 1 MUX with ESP32 for something useful. 2 of them and 30 sensor boards.
I'm tossed between going with just current measurements, MAX471, or ACS712 with the MUX or voltage and current with the INA260, INA219 or INA226.
Since I already have had an accuracy issue with the INA219, I will nix that and it appears that the INA260 module is scarce right now, I'm going to have to go with the INA226 (36V, 16-bit, ultra-precise i2c output current/voltage/power monitor w/alert)
which just by chance has 16 programmable addresses on the I2C-compatible interface so I can NIX the MUX.INA226 data sheet, product information and support | TI.com
TI’s INA226 is a 36V, 16-bit, ultra-precise i2c output current/voltage/power monitor w/alert. Find parameters, ordering and quality informationwww.ti.com
Poo I was so looking forward to programing with the MUX. So in essence that means 2 ESP32's and 30 INA226's.
I will order some of the Max471's and ACS712 also since from AliNoExpress they are reasonable enough, just to have and hold maybe for future experiments and so I can use the MUX.
So my project will be a current and voltage sensor on each cell/pack. I will test the CALB cell for Ah and build a 16s Battery. For the 18650 packs I will build a 14s xxp that mimics the Ah of the CALB ie 40Ah =~16 2600mAh cells which I have plenty of.
Also an INA228 with a Shunt (85-V, 20-bit, ultra-precise, I2C output current/voltage/power/energy/charge monitor with alert)
https://www.ti.com/product/INA228?k...ch-everything&usecase=GPN-ALT#product-details
which I have plenty of evaluation modules measuring Amperage flow(if any during normal operation) and Voltage between the Li and LFP batteries
With voltage and current sensors on each cell/pack/battery this will be a fun experiment, and a great coding experience.
Me too.I'm kinda looking forward to this.
oh yes, same here, but for temperature and voltage. For temperature the lovely DS18B20 (you suggested me that some threads ago, and I'll thank you forever for that!) only uses one wire for data, can connect 14 of them with little effort. For the voltage measurements I have some MUX/DEMUX chips (74138 and 74148) and also was very curious of trying the MUX chip. My biggest doubt right now is how to read voltage from 14 packs: use 13 voltage dividers and calibrate them, or is it possible to MUX both negative and positive? Dunno really, must do some testing... and maybe open a new thread!So my project will be a current and voltage sensor on each cell/pack
LOLAliNoExpress
No not really It has a common ground which interfaces with the Arduino or ESP32. The Arduino can handle a 5V input max and the CD74HC4067it possible to MUX both negative and positive?
