Cant see why my Simpbms is Unhappy
bashers
I'm still working on my BMS build with an i3 battyery.
On restart i my simpbms is unhappy with its current settings in ESS mode. This can only be cheered up by setting to EV mode and then back again:
@CarelHassink can you enlighten me at all?
BMS Status : ESS Mode : UNhappy: 12
Out:0000 Cont:0000 In:0000 Charge Current Limit : 0 A DisCharge Current Limit : 0 A
Modules: 1 Cells: 12 Strings: 1 Voltage: 47.796V Avg Cell Voltage: 3.983V Low Cell Voltage: 3.981V High Cell Voltage: 3.985V Delta Voltage: 4mV Avg Temp: 21.000C
Module #7 47.80V Cell0: 3.98V Cell1: 3.98V Cell2: 3.98V Cell3: 3.98V Cell4: 3.98V Cell5: 3.98V Cell6: 3.98V Cell7: 3.98V Cell8: 3.98V Cell9: 3.98V Cell10: 3.98V Cell11: 3.98V
Temp 1: 21.00C Temp 2: 21.00C Status: 0x0 Bal: 0x0
0.00mA 89% SOC 83660.01mAh
Firmware Version : 270431
Alarm and Warning Settings Menu
1 - Voltage Warning Offset: 100mV
2 - Cell Voltage Difference Alarm: 200mV
3 - Temp Warning Offset: 5.00 C
4 - Over and Under Voltage Delay: 500 mS
Charging Settings
1 - Cell Charge Voltage Limit Setpoint: 4100mV
2 - Charge Hystersis: 200mV
3 - Pack Max Charge Current: 99.00A
4- Pack End of Charge Current: 10.00A
5- Charger Type: Victron/SMA
6- Charger Can Msg Spd: 100mS
7 - Charger HV Connection: Direct To Battery HV
9 - Charge Current derate Low: 0.00 C
Current Sensor Calibration Menu
c - To calibrate sensor offset
s - Current Sensor Type : Undefined
1 - invert current :0
2 - Pure Voltage based SOC :1
3 - Current Multiplication :1
Contactor and Gauge Settings Menu
1 - PreCharge Timer: 5000mS
2 - PreCharge Finish Current: 100 mA
3 - PWM contactor Hold 0-255 :50
4 - PWM for Gauge Low 0-255 :50
5 - PWM for Gauge High 0-255 :255
6 - ESS Main Contactor or Trip :Main Contactor and Precharge
Debug Settings Menu
Toggle on/off
1 - Can Debug :0
2 - Current Debug :0
3 - Output Check :0
4 - Input Check :0
5 - ESS mode :1
6 - Cells Present Reset :12
7 - Gauge Debug :0
8 - CSV Output :0
9 - Decimal Places to Show :2
b - balance duration :60 S time before starting is 60s
r - reset balance debug
When i set it to EV mode and back to ESS it goes to:
BMS Status : ESS Mode : Happy 12
Out:1110 Cont:0110 In:0000 Charge Current Limit : 60 A DisCharge Current Limit : 100 A
Modules: 1 Cells: 12 Strings: 1 Voltage: 47.795V Avg Cell Voltage: 3.983V Low Cell Voltage: 3.981V High Cell Voltage: 3.987V Delta Voltage: 6mV Avg Temp: 21.000C
Module #7 47.80V Cell0: 3.98V Cell1: 3.98V Cell2: 3.99V Cell3: 3.98V Cell4: 3.98V Cell5: 3.98V Cell6: 3.98V Cell7: 3.98V Cell8: 3.98V Cell9: 3.98V Cell10: 3.98V Cell11: 3.98V
CarelHassink
Mr. Bashers,
not sitting next to you and the system in your workshop,
So here's my 2 cents: perhaps you have corrupted firmware, try flash a fresh new copy on your Teensy, and manually restore settings
best Carel
