Detritalgeo
- Nov 29, 2017
- 34
I have noticed there are a variety of units being used for charging and testing capacity. I have not been able to find a thread with a summary of the most common with specs.
I also noticed many dischargers have different cut-off voltage for capacity testing
Perhaps this can be started here, I don't have them all but I can try to compile of the admins can take this over as a sticky if it proves to be a good reference.
1) TP4056 / micro-USB PCB module
Size: 1 cell (must purchase cell holder separately)
Overheat Detection: NO, do not charge cells unattended / overnight
Charging: YES
Charge Current: 1000 mA x 1 cell
Charge Voltage: 4.20 V
Charge mode: CC/CV
Charge Status LED: YES
Charge Complete Beep: NO
Discharging: NO
Discharge Current: NA
Discharge Cut-off: NA
Discharge Mode: NA
Discharge End BEEP: NA
Measure Internal Resistance: NO
Nominal Cost: 0.2 - 0.5 USD per board
Retailer: Ebay, AliExpress, Amazon, Gearbest
Misc. Comments:
- cheap and easy, simply plug into and 5V USB port
- at least 2 versions, 1st without reverse polarity protection and second with (pictured)
Image:
[img=250x200]http://www.communica.co.za/Content/Catalog/Images/I4153156114.jpg[/img]
___________________________________________________
2) NITECORE DigiCharger D4
Overheat Detection: YES(however, no stated cut-off temp, do not charge cells unattended / overnight)
Charging: YES
Charge Current: 375 mA x 4 cell, 750 mA x 2 cell
Charge Voltage: 4.20V
Charge mode: CC/CV, ~50 mA cut
Discharging: NO
Discharge Mode: NA
Nominal Cost: ~$20-30 USD
Misc. Comments:
- good build quality, LCD read out of voltage, charge current and charge time
Image:
[img=286x200]http://img1.indafoto.hu/10/3/3093_5..._92908f988d7fb89e89cff0138fc732a2_l.jpg[/img]
3) OPUS BT C3100 (v2.2)
Overheat Detection: YES (however, no stated cut-off temp, do not charge cells unattended / overnight)
Charging: YES
Charge Current: 200 mA, 300 mA, 500 mA, 700 mA, 1.0 A (1.5 and 2.0 A if only bay 1 and 4 used)
Charge mode: CC/CV
Charge Status LED: LCD Display
Discharging: YES
Discharge Current:200 mA, 300 mA, 500 mA, 700 mA, 1.0 A
Discharge Cut-off: 2.80 V
Discharge Mode: CC
Discharge End BEEP: NO
Measure Internal Resistance: YES
Misc. Comments:
- fan operation is 'not quiet'
- unit known to overheat and suspend charge/discharge, can upgrade fan
- 'auto cell test' function (charge-discharge-charge, mAh displayed)
- Internal resistance measurement known to have poor precision, gives result for general 'health' only (see post #13)
Image:
[img=300x200]https://eu.nkon.nl/magento17/media/...b8d27136e95/o/p/opus-bt-c3100-empty.jpg[/img]
3) FOXNOVO 4S
Overheat Detection: NO?
Charging: YES
Charge Current: 500 mA, 1.0 A (selectable for all, not independent)
Charge mode: CC/CV
Charge Complete Beep: YES
Discharging: YES
Discharge Current:500 mA, 1.0 A (selectable for all, not independent)
Discharge Cut-off: 2.70 - 2.80 V
Discharge Mode: CC
Discharge End BEEP: YES, cannot be turned off
Measure Internal Resistance: NO?
Misc. Comments:
Image:
[img=200x200]https://i.ebayimg.com/images/g/kyMAAOSwpONZQw4L/s-l300.jpg[/img]
4) SKYRC MC3000
Overheat Detection: YES, selectable cut-off temp per cell, fan activation temp also selectable
Charging: YES
Charge Current: selectable from 0.05A - 3.00A
Charge Voltage: selectable from 3.40V - 4.40V with storage option
Charge mode: CC/CV
Charge Status LED: 128x64 LCD Display
Charge Complete Beep: YES, selectable
Discharging: YES
Discharge Current: selectable up to 2.00A
Discharge Cut-off: selectable (2.50V - 3.75V)
Discharge Mode: CC or CC/CV selectable, selectable mA cut
Discharge End BEEP: Yes, selectable
Nominal Cost: $75 - 100 USD (depending on coupon code)
Retailer: Gearbest
Misc. Comments:
- USB connection for remote control by PC
- Bluetooth connection for remote control by phone/tablet
- compatible with standard 3.7, 4.20 and HV 4.35 cells
- Firmware updatable
- very reliable voltage and current values
- very reliable thermal cut-off if a cell begins to heat
Image:
5) MiBoxer C4-12
Size: 4 cell independent
Overheat Detection: YES, shut-down if cell > 70C
Charging: YES
Charge Current: 0.1, 0.2, 0.3, 0.5, 0.8, 1.0, 1.5, 2.0, 2.5, 3.0 A or 'Auto'
Charge Voltage: 4.20V only
Charge mode: CC/CV
Charge Complete Beep: NO?
Discharging: YES
Discharge Current: ?
Discharge Cut-off: ?
Discharge Mode: ?
Discharge End BEEP: ?
Measure Internal Resistance: YES?
Nominal Cost: $45 - $60 USD
Retailer:
Gearbest - https://www.gearbest.com/chargers/pp_1044646.html?vip=3932164
...Ebay, Amazon, AliExpress
Misc. Comments:
- USB port for external charging via cell in slot 4
- Automatic charge current based on cell IR
- Automatic capacity testing
- 'automatic repair' of 0V Li-ion cells
- high precision voltage reference
- charge in your car by 12V plug
- fireproof plastics
Image:
[img=300x300]https://b2brazil.com/sites/default/...uct/image/1_fu_ben__3.jpg?itok=pH3O7j77[/img]
6) Enova GRYfalcon 88
Overheat Detection:NO?
Charging: YES
Charge Current:
Charge Voltage: 4.20V, 4.30V, 4.35V
Charge mode: CC/CV
Discharging: NO
Discharge Current:
Discharge Cut-off:
Discharge Mode:
Discharge End BEEP:
Nominal Cost:
Retailer:
Misc. Comments:
Image:
[img=267x150]http://blog.enova18650.com/wp-content/uploads/2016/06/Gyrfalcon-All-88-Angelo.jpg[/img]
Charging: YES
Charge mode: CC/CV
Discharging: NO
Discharge Mode: NA
Misc. Comments:
Image:
Charging: YES
Discharging: NO
Discharge Mode: NA
Misc. Comments:
Image:
Charging: YES
Charge mode: CC/CV
Discharging: YES
Discharge Mode: CC
Misc. Comments:
Image:
3) FOXNOVO 4S
Charging: YES
Charge mode: CC/CV
Discharging: YES
Discharge Mode: CC
Misc. Comments:
Image:
4) SKYRC MC3000
Charging: YES
Charge mode: CC/CV
Discharging: YES
Retailer: Gearbest
Misc. Comments:
Image:
5) MiBoxer C4-12
Charging: YES
Charge mode: CC/CV
Discharging: YES
Discharge Mode: ?
Retailer:
Misc. Comments:
Image:
Charging: YES
Charge Current:
Charge mode: CC/CV
Discharging: NO
Discharge Current:
Discharge Cut-off:
Discharge Mode:
Discharge End BEEP:
Nominal Cost:
Retailer:
Misc. Comments:
Image:
