Cell Database Submissions and Updates
bbbbrass
New cells, don’t seem to be in database. Harvested from dewalt 18v power tool battery pack. Initial charging data shows 4.17 -4.18 voltage mAh ranging from 976-2394 on 4 batteries.
MilliOhm readings from 30-36. Have 10 batteries, will report more findings as testing continues.
Google LG HE2 and you will find plenty on these red cells.
Should be this cell: LG HE2 (even if 3rd and 4th letter are different): https://www.powerstream.com/p/LG-ICR18650HE2-REV0.pdf
New cells? I can’t find any data or info via google for this size and style battery. They have a cardboard sleeve that slides off. You can see numbers printed on the metal casing.
I harvested 5 cells out of a Milwaukee power tool battery pack labeled Lithium. Sticker on bottom has following info:
18v Li-ion 3.0Ah serial #A95A07225728
These are hacker cells... Anonymous
:D
Oberfail
unlabled cells that are rare, are not really worth putting into the DB
All the cells I have seen like that were really really old they look larger than an 18650. Are they Larger ? 226603 1692
22mm diameter? 66mm long 0? 3Ah qr box?1692 16th week 1992? That is about how old the toshiba cells that had cardboard wrapper I had.
Edub77
I’d say 70mm x 27mm (with the cardboard sleeve, 25mm w/out the cardboard sleeve.)
It would seem the numbers have nothing to do with the size or age. I found 1 25700 cell but it is LTO 2.4V, but many 26700 cells in 3.7V.
Oberfail
Manufacturing and measuring tolerance can vary a bit.
I have a lot of 18650 cells that barely fit into the 18.5mm holder and many that sit in very loosely while all of them are labled 18650.
GaborS
Hi! Found a new cells that I could not find in the database.
LGAAHD2C1865
Found this cells in DYSON hoower packs. harvested more 100 piece out some low voltage they seem ok
thested many of them about 1900 - 2150 mAh.
Some data on the net ( aliexpress) link
SPECIFICATION Brand: LG 1. Nominal capacity: 2100mAh 2. Nominal Voltage: 3.6V 3. Standard Charge Constant Current: 1050mA Constant Voltage: 4.2V End Condition(Cut off): 50mA 4. Fast Charge Constant Current: 4000mAh Constant Voltage: 4.2V End Condition(Cut off): 100mA 5. Max. Charge Voltage: 4.2V 6. Max. Charge Current: 4000mA 7. Standard Discharge Constant Current: 420mA End Voltage(Cut off): 2.5V 8. Fast Discharge Constant Current: 15A End Voltage(Cut off): 2.5V 9. Max. Discharge Current(continuous): 22A 10. Size Diameter:18.3 +0.2/-0.3, height: 65.0 ±0.2 11. Cell Weight: 48g
GaborS
LGGBM261865
Found this cells in DIY pack
some info at: link
Description
LG M26 18650 2600mAh 10A Battery - LGGBM261865
SPECIFICATIONS:
  • Model: LG M26
  • Size: 18650
  • Style: Flat Top
  • Protected: No
  • Rechargeable: Yes
  • Nominal Capacity: 2600mAh
  • Continuous Discharge Rating: 10A
  • Nominal Voltage: 3.65V
  • Approximate Dimensions: 18.4mm x 65.2mm
  • Approximate Weight: 44g
GaborS
in a e-Scooter pack
No Name --- 2500mAh / 3.6V
GaborS
CTECHI --- 2600mAh / 3,7V
found in net: link
resr
LY 18650-AH00, date code(?) FD25, teal sleeve, grey separator, found in a bin, internally shorted._
resr
BFN ICR18650 2000, date code MH60385 17I20, light blue sleeve, white separator, found in a bin, internally shorted._
resr
LGEBM261865, serial number P054B232A2, 2600mAh, dark purple sleeve, white separator, found in a bin charged, addition to collection._
resr
DS 18650F, date code 2017I25, dark purple sleeve, grey separator, found in the bin, to be tested._
