Cell Database Submissions and Updates
dulifa
Today I came across this one's removed from a Toshiba 96Kwh power pack, they are red with red ring also and they are marked Sanyo R1112, i search the forum but I can't find it, any help?
slipkn67
lol 96kwh did you harvest it from Tesla Model S P100D?
R1112 is the date code
Those are some average 2200mAh Sanyo cells
Joe
i think you search for this :
Bjorns
Got a new cell here. its a Sanyo text on the cell HR-4/3AU SANYO JAPAN EDH came out of toshiba laptop battery
Bjorns
Here i got an other new one. looks like LG label reads: 702340904 LGR18650U CG 11 AM A&TB came from a HP laptop battery
Bjorns
I got a Samsung ICR18650-22D SDI 421
McLaurin
Company
Hubei China Energy Li-ion Battery Technology Co.,Ltd
INR18650E2200
Specifications​
3.7v cylindrical li-ion battery 2200mAh 1)500 times cycle life 2)Factory price,Fast delivery 3)1 years warranty 4)CE,UL,ROH,CB,UN38.3,MSDS
High quality li-ion battery, ZNB have 6 years' experience in this field.
Support OEM, supply factory directly price, fast delivery.
Battery passed EC, UL,ROHS,CB, UN38.3 and MSDS certification, factory passed ISO 9001.
Spefication of 3.7v li-ion battery:
ModelZNB 3.7v li-ion Battery
Nominal Voltage3.7V
Nominal Capacity2200mAh
Discharge Cut-off Voltage2.75V
Charge Voltage4.2V
Stardard ChargeConstand charge current 0.2C,Constant voltage 4.2V,0.01C cut off
Standard DischargeConstand current 0.2C,end voltage 3V
Fast ChargeConstand charge current 1C,Constant voltage 4.2V,0.01C cut off
Max. Continual Charge Current1C
Max. Continual Discharge Current2C
Storage Temperature-20~60°C
Cycle Life500times
CertificateCE,UL,ROHS,CB, UN38.3, MSDS
HolyRaven
I was unable to find a datasheet but here are the photos.
Its next up for the discharge test so I currently have no idea of the capacity just a suspicion it may be a knockoff or in relation to the other FST cells already in the database. I'll update this post after the test to maybe give more clarity of which capacity its close to20210604_155305.jpg20210604_155330.jpg
Lucario
Recoverd two of these 18650 from a dead Parkside tool.
Sadly didn't find a data sheet but there is a lot of info on the cell:
Parkside
INR18650E
Light blue wrapping
3.7v
1300mAh
Li-ion
Also this number but I didn't find anything searching it:
20180801 YG
Lucario
Recoverd this 18650 from a broken power bank.
I can't seem to find the manufacturer of it but there are some Infos on the cell itself:
YHBN18650
Baby blue/green wrapping
3.7v
2600mAh
Hope that helps someone
ghare
I have come across some cells I have not been able to identify. The makers mark seems to be "LN" but nothing comes up on Dr Google. Any info appreciated.20210608_173223[1].jpg20210608_173207[1].jpg
Karlredance
From a Black & Decker 20 volt Max 1.5AH battery pack dated March of 2017, I understand that these pictures are not ones that you would like to use for a thumbnail however tearing a cell out of my battery pack just to get a cleaner picture and then have the spot weld it back in was not anything I was looking to do but I wanted to get the cell at least seen
rev0
Here's a datasheet to add for that submission: http://queenbattery.com.cn/index.php?controller=attachment&id_attachment=98
Sin su chon
Hi all,
I have some new LG cells (well they are from around 2013-2016 per the pcb they came out of)
They are out of a drillbattery pack.
LGABHE21865
P322K176A8
If i had to pick a color they are a pinkish salmon red.
I cant seem to find any specs on these, i have 5 of the battery packs and they are all the same cells
Found 20 of these inside Ryobi 40v battery pack.
Thanks for everyone's contributions - keep putting them up, but I have no way of adding them to the official list yet.. They still show up here in google search so still a win ..
