Cell Database Submissions and Updates
I think I've got something new here for the database. Spotted these in the recycling bin at work and thought I would test them out. One needed a trickle charge but the tested out at 2555, 2679, and 2712
Specs are available on the website:http://www.efestpower.com/index.php?ac=article&at=read&did=396
Model: IMR18650
Rated capacity: 3000mAh
Nominal Voltage: 3.7V
Voltage cut-off: 2.5V
Max Charging Current: 4A
Standard Charge: 2A
Discharging Current: 20A
Plus Discharging Current (their words not mine): 35A
Charging Temperature Range: 0 - 45C
Discharging Temperature Range: -20 75C
Hi Guys,
Im inneed of help with an Hoverboard Battery, does anyone know these cells?Are they high capacity charging/discharging?
but dont know these cells...
Thanks
Manufacturer: unknown
Model:ICR18650SY
Form: 18650
Rated capacity: 2500mAh
Nominal voltage: 3.7V
Measured capacity: 2212mAh
Test equipment: Turnigy Accucell-6 80W
Test current: 1A
Cutoff voltage: 2.9V
Weight: 45g
New user here, signed up to post this apparently new battery for the database. Picked this up from a recycle yard and googling the numbers returned no info. There were 6 batteries in the pack. Here are pics and the text from the battery.
B
GE0FHH3
035566 (serial number as they are sequential on the batteries)
3
Got a couple,
First one is a total mystery. Pulled from a pack like this.
According to the pack its11.1V at 8800mAh makes sense for all the cells to be 2200mAh.
Well I tested these with 4 different testers and they come up every time at least at 2500mAh and up.
No markings at all on the gray wrapper even with a searchlight and microscope.
Decided to unwrap one and there were these markings and that's it.
The other one I could not find in the cell database or anywhere else for a matter of fact.
It is self explanatory as far as mAh is concerned but no other specs.
on the SkyRC M3000 the are showing ~2150mAh so not a bad cell.
Just got over a cell that seems to miss in the database.
I found a webpage with specshere:https://www.dnatechindia.com/LG-MJ1-18650-3500-mah-Li-ion-battery-india.html
LG MJ1 18650 Battery
  • Model: LG
  • Part Number: LGGBMJ11865
  • Cycle Life: 400
  • Nominal Voltage: 3.635 Volts
  • Nominal capacity: 3500 mAh
  • Minimum capacity: 3400 mAh
  • Max. Charge Voltage: 4.2 0.05 Volts
  • Max. Charge Current: 1.0 C (3400mA)
  • Max. Discharge Current: 10 Ampere
  • Weight: 49.0 Grams
  • Operating Temperature Charging: 0 ~ 45C
  • Operating Temperature Discharging: -20 ~ 60C
  • Diameter: 18.4 +0.1 / -0.3 mm (Max. 18.5 mm)
  • Height: 65.0 0.2 mm (Max. 65.2 mm)
EDIT:
Found a Datasheet here: https://www.nkon.nl/sk/k/Specification INR18650MJ1 22.08.2014.pdf
EDIT 2:
Possibly the same as LGDBMJ11865:
https://secondlifestorage.com/t-LG-LGDBMJ11865-Cell-Specifications
Model Number: US18650VTC5
Cell Name: US18650VTC5
Sony Code: 49928190
Cell Shape: Cylindrical
Size (with plastic tube) : Diameter 18.35mm max Length 65.20mm max
Weight: 44.3g Average
Rated Capacity (0.2C discharge) 2500mAh 9.00Wh minimum capacity at room temperature,2.0V cut off
Capacity at 1C 2563mAh 9.23Wh average capacity at room temperature,2.5V cut off
Capacity at 10A 2577mAh 8.80Wh average capacity at room temperature,2.5V cut off
Nominal Voltage 3.6V
internal Impedance 13.0m? Typ.measured by AC1kHz
Cycle Performance 70% Min. of Initial capacity at 300 cycles 10A discharge at room temperature,2.5V cut off
Charge Method : constant current constant voltage
Charge Up Voltage : 4.2 0.05V
Charge Current : 2.5A
Charge Time : 2.5h
Ambient Temperature : 23 C
Hey, I found one of the same brand/logo, different number of sides on the top cap, no discernible model number (no luck on finding data either):
And here's a Samsung ICR18650-24B, which appears to be a variant of the 24A/24E that are already in the database. No datasheet that I could find, but there's data on it at Voltaplex and here:https://voltaplex.com/samsung-24b-18650-battery-icr18650-24bhttps://merkandi.us/archive/battery-li-ion-18650-samsung-icr18650-24b-3-7v-2400mah/256007which claims 2400mAH capacity, 3.7V, 800mA standard charge, 960mA "rapid charge",2.4A max charge, 4.8A max discharge.
B
GE0FHH3
3
This is likely a Sanyo UR18650A:https://secondlifestorage.com/t-Sanyo-UR18650A-Cell-Specificationscheck the side for a faint imprinted model number.
Model: IMR18650
Standard Charge: 2A
Vape cells like this are usually rewraps of major manufacturer cells. This one for example looks very similar to an LG HG2 (same top cap shape/sides, very similar voltage curve shape:
Data from here:https://lygte-info.dk/review/batteries2012/Common18650comparator.phphttps://lygte-info.dk/review/batteries2012/Efest IMR18650 3000mAh (Purple) 2016 UK.html
Generic 2AH cell to add, closest I can find on spec/appearance is the following cell from Greenway battery:
https://www.globalsources.com/gsol/I/Lithium-ion-battery/p/sm/1169141944.htm#1169141944https://www.alibaba.com/product-det...?spm=a2700.7724838.2017115.193.77d072f753Wbmjhttps://www.greenway-battery.com/product/Battery-Cell-30.html
18650E-0200Spec states 2.2AH typical capacity, 4.4A max discharge rate.
And here's a generic 3200mAH cell I bought from eBay. Thought it would be fake but turns out to be real (or at least close to spec, 2963mAH tested in a Miboxer C2 4000 at 1.5A):
Again hard to find sources but I believe it is a DLG cell, INR18650-320:https://www.alibaba.com/product-det...spm=a2700.7724857.normalList.7.61cb6806abg0h7https://www.alibaba.com/product-det...pm=a2700.7724857.normalList.58.61cb6806abg0h7https://www.alibaba.com/product-det...pm=a2700.7724857.normalList.68.61cb6806abg0h7
Spec states 3.1AH minimum, 3.2AH typical, 3.2A max charge current, 6.4A max discharge current (to 2.5V), <40mOhms IR.
Update, got a datasheet for the INR18650-320 from DLG. 1C charge, 2C discharge max.
  • INR18650-320_DLG.pdf
It appears to come in a blue wrap with no other markings/barcodes also:
UR18650AA
Datasheet:
Sanyo AA 18650 Battery, 2150mAh, 4.3A, 3.6V, Grade
INR18650-32E
Datasheet:
Official specifications (lygte-info.dk)
Typical Capacity: 3,200mAh (0.2C, 2.50V discharge)
Minimum Capacity: 3,100mAh (0.2C, 2.50V discharge)
Charging Voltage: 4.2V
Nominal Voltage: 3.65V (0.2C discharge)
Charging Method: CC-CV (constant voltage with limited current)
Charging Current Standard charge: 960mA
Charging Time Standard charge: 5hours
Max. Charge Current: 3,200mA (not for cycle life)
Max. Discharge Current: 6,400mA (for continuous discharge), 9,600mA (not for continuous discharge)
Discharge Cut-off Voltage: 2.50V
Cycle life: 500 cycles to 70% with 3200mA discharge, 300 cycles with 6200mA discharge.
Cell Weight: 50g max
Cell Dimension: Height : 65.2mm max, Diameter(max.) : 18.50 mm
Operating Temperature (Cell Surface Temperature): Charge : 0 to 45C, Discharge : -20 to 60C
Storage Temperature: 1 year : -20~25C, 3 months : -20~45C, 1 month : -20~60C
Another mystery generic cell from a generic 6-cell laptop pack:
Capacity tested 584mAH/181mOhm and 558mAH/163mOhm, so not sure what the original capacity was since this must be very heavily ddegraded. I'll update if I ever find the cell info, but after a quick search of the model number(s) (FC14-HE-L097) on Google and Alibaba, no hits.
I guess i was not allowed to add pictures to the cell database so ill post here I have some LGDDBHE21865 they are 2500mah and came from a ryobi 40v 5Ah
Note: We need pictures to create a database entry. You can upload them where it says "Drop files here to upload" in the full post editor or new thread editor.
Found a cell I could not find in the database. The green one listed for ICR18650NH does not match.
Unknown brand from a laptop. Capacity rated in Wh which is unusual.
Haven't found these in the database, so here are some photos
1) LN INR18650
Capacity test showed 2022 (discharge with 500 mAh).
2) DSD ICR18650T
Capacity test showed 1922 (discharge with 500 mAh).
3) SZNS 18650 3,7V 7,4Wh
18650 3.7V 7.4Wh SZNS
Rated Capacity - 2000mah
Rated Voltage - 3.7V
Cut-off Discharge Voltage - 2.75V
Charge Upper Limit Voltage - 4.200.05V
Charging Time(Std) - 4.0hours
Standard Charging Circuit - 0.2C A
Charging Circuit - 0.5C A
Standard Discharging Circuit - 0.2C A
Fast Discharging Current - 0.5C A
Max Discharging Current - 2C A
Weight- about 50g
Height - 65mm
[size=small][size=small][size=small]Capacity test showed 2185 (discharge with 500 mAh)[/size][size=small][size=small].[/size][/size][/size][/size]
Hi,
I have found those in a different color. Here are some pictures
[size=small][size=small]Capacity test showed ~2200 (discharge with 500 mAh)[/size][/size][size=small][size=small].[/size][/size]
