Cell Database Submissions and Updates
Here are some more cells, that I have found in batteries for scooters. Most probably these are from some Chinese manufacturers. Battery packs were 10s2p 4-4,4Ah, so cells should be at around 2000-2200 mAh (originally).
1) HL 18650-AH00
2) ICR 18650MR
3) INR 18650HP
4) INR18650HE
Datasheet:http://www.batteryspace.com/prod-specs/6321.pdf
I did not find these on the database it is EVE brand and 2Ah they came from a ryobi 40v 4Ah battery
I couldn't find anything on Google about this cell - LGABE2L1865. Running a 500mA discharge test now for voltage curve/identification. Most likely a high capacity/low power cell based on the equipment it came from:
Great capacity/IR result; 3225.7mAH, 46.3mOhm (DC).
Voltage curve for identification purposes (normalized, X-axis in capacity):
I just collected a cell that matches the appearance of UR18650FM in the table (Red wrap, Black ring) but is embossed as UR18650Y.
Photos? Perhaps a fake?
kj3lll3 said:
Will post a new battery in next post
HZNB INR18650P2000
Orange whit white ring
Some info
[quote pid='59398' dateline='1581016459']
I can'tbelievethis is the onlyreferenceto this cell I could find [and only indexed in the image results].I pulled a 10s2p
42v pack out of a hoverboard. Beforeopening it,I was pretty happy as the BMSwas all built in to one neat package in a
mold injected package. Upon openingthe pack, itwas rusted... water damaged so Idisassembledit. 6 of the 20 cells were
able to be restored with a Nitecore charger. I can't contest to the capacity or accuracy of stated specs, but I doubt thechemistry
is misrepresented as the device I removed it from was used for quite a while.
It was removed from board that was labeled with the following.
YongKang Dingchang Industry Trade Co Ltd Model LBW01 UL number E484387
manufactured 11-2016.
Hope that helps
[/quote]​
Have some new Li-Po here. The print is very difficulty to see. But i have it:
- II4EJT3
- OO12337
I upload a video but I cant add a url... Please write me to get the link of it.
- II4EJT3
- OO12337
I'm pretty sure this is a UR18650F, but I'm having trouble finding a reference to confirm it. It's one of the classic red ring Sanyo "heaters". I've got a few, I'll take a picture when I get back on Friday.
I've got a new addition, a DBK INR20650A3350. I can't find any data on it, but it was from a Blackweb 20100mAH power bank (here's a link to the OEM manufacturer:https://www.alibaba.com/product-detail/20100mHA-white-OR-black-POWER-BANK_62165882548.html). Measures just about 3350mAH as stated.
Hi all,
I have some new LG cells (well they are from around 2013-2016 per the pcb they came out of)
They are out of a drillbattery pack.
LGABHE21865
P322K176A8
If i had to pick a color they are a pinkish salmon red.
I cant seem to find any specs on these, i have 5 of the battery packs and they are all the same cells
Malodin said:
Hi all,
LGABHE21865
P322K176A8
It's an LG HE2:https://secondlifestorage.com/showthread.php?tid=1720 just seems to have a faded or off color wrap.
I didn't find this version if the Hitachi Maxell cells in the database. Purple wrapper, black insulator. Model number INR18650PB2. Sourced from a Hitachi 18V battery pack.
