I guess I have a new one here.
This one is dead. It was taken off from a Parkside power tool pack that for some odd reason it stopped charging.
I called the Manufacturer and they say they only guaranty the power packs for 6 months .
This pack was barely used and because it was just over 2 years old,it wasn't covered by any warranty.
So I openedup the packand measured the voltage of every individual celland found this one was dead and all the others werebetween 2.7v and 3.0vish.
I charged them back up individually while they were in the pack using my Liitokala chargerand crocodile clips to 3.85v without any issues.
I will keep the remaining 4 cells in case I need them for my other powertool batteries.
I also found some info online regarding a similar cell:
This one seems to be of a similar series, it came out of a Dell J1KND replacement chinese battery. Initial voltages of the 3 pairs were 1.16V, 1.63V and 1.84V). Charged to 3V using NicaD setting of imax B6 charger and then charged to 4.1V using LiPo setting,the respective pairs showed about 2700maH per pair.
4[/ATTACH]
Kabuki pid='60739' dateline='1584990839']I didn't find this version if the Hitachi Maxell cells in the database. Purple wrapper, black insulator. Model number INR18650PB2. Sourced from a Hitachi 18V battery pack.
Found inside the original JBL Control X wireless box.
2 Pcs in total, didnt found this exact one in the database. Text on the battery:N18650A Q260 0160B 03271 Battery info:Should be if i am correct: 2600mAh, 7.4V, 19.2 Wh, further unknown
Also didnt find this one in the DB, found those (6pcs in total) inside my dead Asus laptop battery. Text on the battery:LB-YN/A2 2050mAh LIBOWER RABEOE 011 Battery info: (written on battery case itsel): 11.1V, 4400mAh, 49Wh (total specs of the whole battery pack, so not from a single battery.)
I guess I should probably wait till I have tested them but these were in a 40v Black & Decker tool battery from canon the battery said it is supposed to be 2.5AH but I see 15 on the cells so probably more like 1500mah I believe the pictures are clear but they say(THISS 18650HR15 2019.08.03 3.6V)
I got some more that came from a laptop battery with 4s1p the color is a little weird but it's about the same as those Panasonic
Found these in a Sony VGP-BPS2C battery pack. Cell origin: Japan, capacity 2600mAh. Last 8 digits are probably serial number as all 6 have different numbers._
Found some LG chem blue cells ( as opposed to cyan ) Named : INR18650s3 +DS190G095AE-
I searched the forum for info on those but none popped up. I added the manufacturer square code thingy because i could >
Edited top picture to better fit database
"New" Zell for the Database. Taken from a fairly old laptop Battery
Brand: YikLik (YLE)
Type: INR18650A205
Nominal Capacity: 2050 mAh
Minimum Capacity: 2000 mAh
Nominal Voltage: 3.6 V
Internal Impedance: </= 48mOhm
Energy: </= 7.38 Wh
Standard Charging: 410 mA
Quick Charging: 2050 mA (1 C)
Charging Voltage: 4.2 V
Continuous Discharging: 5 A
Cut-off Voltage: 2.75 V
Weight: </=45g
Came from a snap-on 18v lithium battery pack. The pack was a 3.0AH pack so the cells just be around 1500MAH. the pack was made April 2011 and that is the closest I can come up with for an age of these cells
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
