GoneDiving
- Jan 17, 2020
- 26
I've received 48 280ah Eve Lifepo4 cells. I'm attempting to balance them all in parallel at 3.40v using my 20a power supply. However, the parallel string is only accepting ~8a at 3.40v.
The batteries were received at 3.30/.31v with two at 3.28v. Charging at 3.50v gives ~15a, 3.60v gives the full 20a.
I would have expected the paralleled cells to receive the full 20a when first connected to the power supply. Should I be concerned or is the low current due to the small voltage difference between the power supply (3.40v) and the pack voltage (3.31v)? Can I expect faster charging when the finished pack is connected to two PIP5048MKs with 120a charge capability?
FWIW: I've confirmed that my power supply can deliver 20a at 3.40v.
My intention is to balance all cells in parallel at 3.40v then charge in series to 3.60v max per cell, identifying/noting any cells that have different capacities, then top balance in parallel at 3.60v.
Many thanks.
Many thanks.
