rodagaster
- Feb 9, 2018
- 16
Hi guys i needa bit of advice regards charging a 3s5p 18650 pack i made 3 of these packs and 2 charge fine but 1 pack is so slow it can take days to charge from 10.6v upto 12.3v i have fitted a new bsm board thinking that may be the problem to no avail then i resoldered all the connections still no change the cells i am using are samsung 1500mA and they tested between 1350mAH to 1470mAH i am using a b-max clone ,i am also having the same problem with a 3s10p pack so any help or suggestions would be appreciated thank you .
