In this thread I will try to explain the do's and don'ts for using TP4056s.
Can I charge my S1 Pack quicker with more than one TP4056?
Yes you can but don't connect the protected outputs together otherwise only one will charge your Pack.
Can I charge my S3 Pack with three tp4056?
Yes and no! If you Connect them to the same 5v Supply they will blow up because you are shorting them out because the USB terminals have the same ground (trust me if tested that). But if you use 3 Powersupplys you are good to go! You could even use Qi Charging Pad and Receiver to isolate them ground wise, which is maybe interesting for small Solar charingsystems.
Can I use the 3A Protection in Paralell and get a bigger Amp cut off?
I haven't tested that jet but I will in the Future! Let me now if know that already.
That's all that I could think of for the moment. If you have any questions or want to know something just ask.
@HBPowerwall promise keeped!
