whoinow said:Panels are up! Picture from the front was taken early evening, thus the shading.
Now that I have 2 solar chargers, my Batrium to Schneider translator needed to control them both. The translator can now support N chargers and will set charging currents from the Batrium (limited, full, etc).
I have also setup influxdb with Grafana to show data from the Batrium, IotaWatt and the Schneider equipment. Pretty happy with the layout and dataset so far.
Stingy49 said:whoinow said:Panels are up! Picture from the front was taken early evening, thus the shading.
How much dothe surrounding trees/houses impact your solar?
Great walk-through! Thank you for sharing the video - that was very thorough.whoinow said:I get a lot of questions about my powerwall, so here is an overview video:
I ended up using the SPIM08 in my RV as well. Not with the same pack design, but used grommets and threaded rod to put the packs together in a 7S configuration. I used cheap chinese bms's that have worked well so far in protection. One of these days I will start a build thread. I just want to pretty it up first before I post anything about it. HahaAirstream said:whoinow said:I get a lot of questions about my powerwall, so here is an overview video:
Chris, thanks so much for documenting this build, and all the great information. I too am seriously considering these cells for a RV powerwall in my camper. Your build is the best and most informative that I can find with these cells.
Not to ask for more, but a final writeup or video on how you built the packs, what parts were used and thoughts after using them for a while would be awesome. I am going to copy your pack design for my own 24v setup.
Thanks again, Great work!
boostinsteve said:I ended up using the SPIM08 in my RV as well. Not with the same pack design, but used grommets and threaded rod to put the packs together in a 7S configuration. I used cheap chinese bms's that have worked well so far in protection. One of these days I will start a build thread. I just want to pretty it up first before I post anything about it. HahaAirstream said:whoinow said:I get a lot of questions about my powerwall, so here is an overview video:
I do have to say, Chris, this is one of hell of a build. We are building a setup in my fathers shed right now, and shares some similarities.
