Hola como comprobar un bms con un multmetro
Hello how to check a bms with a multimeter
Puedes usar el primer negativo, a cada uno de los positivos.... pero
You can use the first negative, to each of the positives ... but
Use the multimeter to measure each cell.
Compare to what BMS says.
To test bms voltage cut-off point maybe use a variable power supply
