Connect bms daly 16S with active equalizer
mohamadmoh20102010
Hi guys
I have problem when i connect the bms daly 16S with active equalizer balancer work normally but when i turn off the circute breaker and turn on the bms appear fualt and should be replace the bms
Roland W
The circuit breaker is 2-pole and disconnecting both + and - ?
