So in this 18650 power wall/pack community it seems the norm is to build large packs of cells in parallel then connect them in series to get the required Voltage.
But if 1 cell went down the voltage of the whole pack would drop significantly and would probably be disconnected by the BMS or to low for the inverter to use.
I recently read somewhere, maybe on here but cant find it now, that maybe best to use lots of 24v Packs (say 7s1p) and connect them all in parallel. So if one pack went down the voltage would not be affected at all but capacity would be reduced by a small amount and it would be far simpler to replace/repair a small 7s1P pack.
I Guess that each small pack would need its own BMS but given the size these would be small BMS's
Or is this a bad idea?
