Hi All, I am a newb so please go easy with me
What I need help with is getting some advice about converting power tools, reading various posts I have been able to ascertain that 18650 cells with high amp rating are the type of cell I need, I gather that each cell is between 3.7v and 4.2v, but I am not sure what I should be using to match the voltage of a drill I want to convert to Lithium.
The existing cells were those 1.2V, I think Ni-Cad and the battery was 18v, so my choices seem to be 4 or 5 cells but what I am not clear about is whether to count the 3.7v or the 4.2v ?
So should I use 4 or 5 18650 cells?
If I go with 5 cells then would 21v damage the drill?
If I go with 4 cells will an 18v charger damage cells only capable of taking 16.8?
Should I use a buck booster to decrease the voltage to 18v or 16.8?
What about the existing charger, I gather it is NOT suitable, but as I will be getting a BMS does that mean it can be used?
The existing charger outputs 18v @ 2A, is it going to be too much for Lithium cells being 2A?
If the existing charger is not suitable then what is the optimum charger amps to get?
If I fit a DC jack for charging can I use any charger on eBay once I have the appropriate amps from question above?
How do I find a decent but affordable BMS from eBay or Ali Express (never used the latter), I read pretty bad reviews online about some BMS.
The cost of the drill is not huge so I want to keep it affordable to avoid dumping drill into landfill.
In these projects is there any other circuitry I need?
Thanks in advance.
| Cells | Cell Voltage | Total |
| 4 | 3.7 | 14.8 |
| 4 | 4.2 | 16.8 |
| 5 | 3.7 | 18.5 |
| 5 | 4.2 | 21 |
Thanks in advance.
