My BMS finally arrived from China! Still plugging away at testing cells though. So far, I've done around 70 or so, so I'm almost done. The best 66 will go in the battery.
I've realized I can't get a 4A fuse, so I'll make due with a 5A. Using the axial glass 0.5A fuses on each cell, that would allow the battery to deliver almost 11A before they start to blow. So a 5A main fuse will definitely pop before that. (I hope.)
I've been playing with an actual wiring diagram, to better imagine where all the parts will go. Here's what I've got so far:
https://i.pinimg.com/originals/75/be/49/75be49c37ec7f697bf060706130b692c.jpg
I definitely wanted a Voltmeter to show the battery status, but I decided to spend a couple extra bucks (I know, unusual for me.) on a Wattmeter. This will show Volts, Amps, Watts, and Whrs, to give me a better idea as to how the battery actually performs vs my math estimates. Plus, it has a low Voltage alarm that can be set. The BMS should shut it down automatically if the Voltage gets too low, but I've never really trusted BMSs.
If I can fit them in the box, I'd like to have the option of taking a battery charge controller and the AC adapter, in case I come across electrical outlets in my travels. Once I get the box, I'll be able to do a mockup of all the parts and see what will fit, and what physical shape I'll make the battery.
