Dala emulator and battery soc calc
mbu10
Good morning
Just been thinking about the calculations on max and min soc within the inverter and battery
So if you set the inverter to 80% and 20% and you have the same figures in the emulator
Would you not have
Emulator 40% that you do not use
And inverter 40% you do not use...
But if you then take that 24kw and remove 40 %(emulator restrictions)is 14kw usable of 24kw battery from the emulator side
But then if your inverter is following the same rules cause of scaling(so it sees 100% (at 80% ) and empty at 20%)
Does that then mean that 14kw has a 80/20 (inverter side limits)with 40% is 5.6 which means 8.4 usable
I am sure this is not the case
But thought would ask
Martin
