Dala's Battery-Emulator
Hi all,
I am thinking of connecting a Growatt ARK to a Fronius Symo Gen 24.
What do you think - would this work with your battery emulator?
I am pleased to announce that a new version of the Battery-Emulator has just been released. Checkout the release notes for 8.9.0 below!
Some excellent news, I have been able to perfect the CMFA-EV platform integration over the past few days. This is opening up a whole new platform to be used with the Battery-Emulator!
First pack running! 🎉
Hi,
I'm not sure if my manual balancing is working correctly.
I charged my battery to 99% and then ran the manual balance for almost 2 hours, as you can see the battery started discharging @ 99.8% and 362V for quite some time. I left it for quite a while but it just sat with a small discharge current.
the following screen shots are with the manual balancing active.
The following screenshots are after turning off balancing
Should this have continued to charge above 100% or has it stopped because the cells are balanced?
Thanks heaps.
It is not. Tesla LFP batteries are currently not possible to balance properly. They will drift overtime. We are working on a fix (by sending more correct CAN data towards the batteries). Lots of people on the Discord are tinkering and discussing this issue.
No worries, thank you I'll keep an eye on the Discord.
Good news all, there is a new version of the Battery-Emulator available! This version adds support for the entire CMFA-EV platform (Dacia Spring, Renault K-ZE), along with support for the Standard Range BYD Atto3 50kWh battery. There is also a ton of bugfixes and new features, for instance, we can now reset Tesla batteries via UDS instead of unplugging the BMS wires incase the battery enters a fault state! Oh, and we can also do negative SOC% scaling for those pesky inverters that set hardcoded minimum SOC values. Checkout the full release notes on Github: https://github.com/dalathegreat/Battery-Emulator/releases/tag/v8.10.0
Hello, Dala can you share schematic how to connect two lily go board to Sungrow sh10rt inverter and Nissan leaf 2011 24kwh battery
Fronius recently released a software update that broke compatibility with the Battery-Emulator. We were able to triage this on the Discord server, and successfully deploy an update to the BYD-Modbus protocol. Checkout the release notes for this new version of the Battery-Emulator below!
Hello, Dala is use 19 pin in this project? if its use where is connect it?
Hello, i'm powering a Solax X3 + Kangoo Battery (22kwh) but i'm stuck because i have a cross after Battery. I can see (Battery : X Inverter : V)
But I don't have fault or event that can explain that.
I have read all guildlines and wiki but i'm stuck.
As I can see on Dala Answer, i want to go on Discord channel, I don't find It. Can someone help me?
Hey @Dala . Does the battery emulator support the Peugeot bigger batteries from the vans please? Something like this: https://www.ebay.co.uk/itm/135668377356
If not, are there any plans to do so please?
Also, question re the stark CMR, is it possible to add two packs to the one stark CMR? So if I had an inverter with two battery inputs, I could, in theory, hang 4 packs off the inputs using 2 stark CMR's and 2 sets of identical batteries?
@Mechsman Those batteries are not supported yet. If you want to help, see the Wiki for more info on what is required to integrate a new type of batteries: https://github.com/dalathegreat/Battery-Emulator/wiki/Data-needed-for-new-battery-integration
You can run some batteries in Double Battery mode, which means the packs are put in parallel and appear as one big battery. This way you can make a 200kWh battery for any supported inverter. See the Double Battery Wiki page for more info: https://github.com/dalathegreat/Battery-Emulator/wiki/Double-Battery
I can answer myself
There is missing line code on battery kangoo.cpp
At the end, it miss contactor line and 96s line.
Now it works like a charm.
Hello, can I use SD card pin for contactor and stop button? because I need additional can in my configuration.
Its change in hw_lillygo.h file or some there else?
