Very much in the planning stage.
Thanks ynot, MFB Dan, cak Just what I need.
My parents have a dead lawn tractor craftsman LT2000, This model has a belt driven hydrostatic transmission so with a electric motor that is short enough to fit between the input shaft and the seat would work probably would work with along one too i believe that there is enough room between the transmission and seat firewall. have to pull the body of the tractor and see. This option could work for a large tread mill motor. Will have to remove the tractor body to see if what I think will work will actually work.
Many treadmill motors are rated for 90v-130v dc. although I have read they work at lower voltages. I am not comfortable working with high voltage systems (48v)51.8v nominal is about as high as I want to go. So if I were to parallel boost converters susceptibility as https://www.ebay.com/itm/143731395097 or https://www.ebay.com/itm/402823088655? would that let out the magic smoke from the boost converters . I could get the voltage but in order to get the amps needed I would need to parallel several of the converters. Although I could just go with a new motor from https://www.goldenmotor.com/ and motor controller.
Later floyd
Later floyd
