So this guy is contradicting major physics?
EDIT: I should be saying practical engineering, physics he's quoting is OK, except Atlantic cable issue.
There's some serious misrepresentations & knowledge gaps in that video:
- "no continuous flow of electrons from a power station to your house... "
The way AC power is generated in power stations is by a rotating generator with magnetic fields in the first place.
Rotating device makes magnetic fields move through coils of wire, which makes AC current.
Yes there's transformers in between but transformers change electron movement to/from magnetic fields so you still have electrons being forced to move along cables to/from each side of a transformer.
- "why are the electrons not carrying energy back to the power station....."
They can, generators in power stations work like "motors" if they are "fed" energy. But the real point is energy (work) is put into pushing the electrons at the power station & at your place they release that energy, eg ("working") heating your radiator. So there's no energy to "go back" to the station - the station is drawing some electrons in to make up for pushing more out again in the AC mains. Bit like a water pump & a fountain, water does a loop.
- his poynting energy vector diagrams have the directions all screwed up.
Energy is not leaving the battery sideways like he claimed, fingers should wrap around battery & thumb points out of end of battery. Negative wire thumb points back to battery to make the loop not the same way as positive wire.
At low frequencies (DC & mains AC) there would be no fields without the electrons or the wires, so claiming it's "all by fields not electrons" is obviously rubbish.
EDIT: based on the discussion in the EEVBlog video below for most practical power engineering (DC & mains AC) we can ignore the field parts.
Notable exceptions to this being AC mains through the metal wall of an enclosure & high voltage power distribution lines.
- his opening question re very long loop light turn on answer is BS as well, we all know it takes a obviously noticeable time for signals eg by fibre on long distance phone calls to travel a significant distance.
EDIT: OK I'll back up on this last one also based on the discussion in the EEVBlog video below. The 1m bit is the critical bit, since we almost never build a wiring structure (in power systems) like that (a "flat sideways loop", never mind the size) it's academic.
