rebelrider.mike
- May 25, 2017
- 614
A fun thought experiment for now, that if it goes well, I may actually build.
Recently I discovered that my old store-bought LFP battery kicked the bucket, and I'll probably replace it with a lead acid battery. But I have almost all the parts sitting around to build an LFP battery, and I figured designing it would be fun. I have 16 LFP cells sitting around from the failed cargo camper project, and I'd like to make some of them useful. So here's a few considerations I've been thinking about:
- Will the battery get too hot? No. The motorcycle has no engine bay to collect heat. It will be sealed in its own container away from the engine.
- Will the battery get too cold? Kind of. I generally don't ride when the temperature is below 40F, so it's not usually an issue. I may have some flat 12V heating elements that could go in between the cells. That might be more efficient than using the current to the headlight to warm up the battery before starting. (Which is the conventional way to do it I'm told.)
- Will the battery turn the engine over? Maybe. The maximum momentary current for each cell is 300A. That should be enough to turn the engine over. But I'll need to give it a try.
- Will the alternator over Volt the battery? No. The maximum voltage of the battery would be 14.6V. The alternator puts out less than that. I don't remember the exact value.
- Will the alternator over Amp the battery? No. The alternator maxes out at 40A. The cells are rated for 60A maximum charge current.
- Will the battery over Amp the alternator? Not sure. If the battery were dead and had to be jumped... I'd have to measure how much current the battery would draw. Worst case: the inconvenience of not using the motorcycle until the battery is fully charged.
- Is a BMS feasible for this application? Not sure. Theoretically, I'd need 300A to turn the starter motor, and a few more Amps to run the headlight and ECUs. So I guess I'd be looking at a 400A BMS. But 99% of the time, the battery would see less than 40A in or out. Also, a 400A BMS is going to be way too expensive.
The old battery didn't have a BMS. It did have a tiny cell balance board. I'd want at least that, plus a way to check each series, and a fuse on the positive wire feeding all but the starter motor. Something like this:
Maybe if I could find a 40A BMS that used the positive side instead of the negative side. It would at least protect the battery when not starting. Anyone have any creative ideas there?
