- Dec 15, 2018
- 2,125
This link - https://www.solarreviews.com/manufacturers/grape-solar/solar-panels/grape24121gsstargsstar100w - shows
At 2s, the VOC = 43.8v. At max charge, your battery could reach 29.2v.
BTW - Can you share the exact Charge Controller you're using? and its specs?
The way MPPT works is that every x seconds or minutes it checks voltages to find the maximum power (watts) it can put into the battery. The MPPT algorithm will typically settle on a lower voltage than VoC. The ambient temperature affects this as the when the panels get hot they have a lower voltage (lower than 43.8) and if it's winter / freezing it will be higher.
That's what the "Temperature Coefficient" is used for - you apply this coefficient to the base VoC to see what the VoC would be for different temperatures higher and lower than the base VoC. You're panels show this:
Bottom line - You're charge controller's will probably (just a guess) not go lower than 80% of Voc. 43.8v * 0.8 = 35v. 35v is still higher than 29.2v max of your battery - so it should work but it's close enough that I'd verify things once you get it working, especially on a hot summer day.
TMI - If you can find the graph of your charge controller's MPPT it will show you the curve of maximum power and you could get a little more detailed on all this. There may even be something written in the user manual that will help clarify this topic.
Short Circuit Current (ISC) | 6.13 |
Open Circuit Voltage (VOC) | 21.9 |
Temperature Coefficient | 0.32 |
