DLG N18650 Cell Specifications
TheBatteries
Administrator
Brand:DLG
Model:N18650
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
440mA Standard
4400mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.3apower.com/product/html/?59.html
Pictures:
I just found some more of these in a 9 cell 'LBI' 10.8V 71Wh laptop pack
Looks like they are made by DLG in china
Specs from this website: 3apower.com/product/html/?59
DLG18650 2200mah 3.7v rechargeable battery cells Li-ion battery
Voltage?3.7v
Capacity?2200mah
Size?18*65mm
Internal resistance;Lower than 48
Life:1000cycles
Delivery:2~6days
Grade;A
1. Nominal Capacity: 2200mAh(0.2C discharge)
2. Charging Voltage: 4.2V
3. Nominal Voltage: 3.6V
4. Charging Method: CC-CV (constant voltage with limited current)
5. Charging Current
Standard charge: 1100mA
Rapid charge: 2200mA
6. Charging Time
Standard charge: 3hours
Rapid charge: 2.5hours
7. Max. Charge Current: 2200mA
8. Max. Discharge Current: 4400mA
9. Discharge Cut-off Voltage: 2.75V
10. Cell Weight: 44.5g max
11. Cell Dimension:
Height: 65.00mm max
Diameter: 18.40mm max
12. Operating Temperature
Charge: 0 to 45C
Discharge: -20 to 60C
14. Storage Temperature
1 year: -20~25C
3 months: -20~45C
1 month: -20~60C
Tested a few so far and results are 2470 - 2530 mAh
(discharged from 4.2V to 3.0V on 1.0A draw on B6-mini)
The text on mine is 'N18650 E09E E24D5 50991'
all the cells in the pack have consistent labels except for the 5XXXX at the end.
Yeah 99% sure that last number is a sequential serial number. That's the way most of these Chinese label cells are.
I can confirm 2410-2606. How are these rated at 2200? Very confusing
I've found a green variant. As far as I can tell they are the same cell, just a different color. Mine all tested in the 2200mAh ballpark, but with IR in the 80m? range, high enough above the makers reported as-new IR for me to believe these had an as-new capacity similar to what others have reported. Anyone out there with a high tested capacity on these cells able to provide and IR measurement?
i have had a bunch of these cells come in from new but defective laptop packs.
averages in the 2350's@1a.
the high readings some get may just be inaccurate test results from some chargers.
my tests were made with an original triton.
i do have a datasheet from dlg but its for newer series.
  • DLGyuanzhuxing(2).pdf
got in 250+ amazon return defective lb1 alienware 9 cell packs with these.
every cell good.
the 2 mosfets on the bms were burned on most packs.
