507PowerWall
- Jun 6, 2020
- 103
OffGridInTheCity said:I found this youtube -https://youtu.be/_tKPY1YF6pg @5:15 -showing a discharge test at around 1000ma and capacity of 2500mah (out of 3000mah). Of course you should run the common DIY test protocol for yourself.
Assuming you're design is a typical DIY powerwall (<1000ma/cell discharge design)- and the price / quantity is good for you - I don't see why you shouldn't use them![]()
507PowerWall said:Well, I have lots of EBL AA/AAA rechargable and are the best for me for years... but the main reason of the post is if EBL does it good as well in 18650 ....
507PowerWall said:More over this battery:
https://thegunzone.com/best-18650-batteries/
Regards from Panama
kc8adu said:yes that whateverfire color scheme gets my suspicion up.
but the large number of their 26650 5000mah cells i have had in service for several years sets a good track record. average 5200@1a.
i guess i would have to get some and test.
hard to take anything on that site as accurate as its just a amazon affiliate kickback site.
giving any whateverfire over 3600mah cells any standing at all renders the whole thing suspect.
its likely a bunch of bot spew.
as we all know(at least most of us) the best has to take into consideration the application .
Regards from Panama
