- Jan 7, 2017
- 7,538
I was in Lowes the other day, and wondered into the electrical section and started looking at the yellow tags. I came across a Door Bell Transformer
Doorbell Transformer
[img=300x300]https://mobileimages.lowes.com/product/converted/016963/016963125018.jpg[/img]
So, I was thinking, since the transformer outputs 8V @ 10A, you could use it to charge a 2s (or 3s if LiFePo4), being about 6.4 -8.2V. Though, the 8.2V would be higher, so this probably would not work. However, if you use two diodes in series (or one with the right value), you could have the forward voltage drop low enough for 4.2V to charge 1 cell.
But, if we go with th 16V @ 10A, then we can do the 4s setup (12.8V - 16.4V). Again, we are slightly needing higher than 16 for full charge, but if we did 4.0V then it's doable. A 3s setup (9.6 - 12.6V) is doable with 2 diodes in series.
And then again for the 24V windings, we could do 6s.
I know the voltages are actually slightly lower than what we need, but we could use this transformer with a buck/boost converter and get good results.
Now, there's another option. Instead of using it to "charge" the cells, how about using it to "power" other devices.
So, we have a 24V battery (22.4 - 29.4V) and we want to power a 120V AC device. This would make a crude inverter. Get a few FETs, resistors, and crystals that'll drive the FETs at 50/60 Hz, and we have a modified sine wave inverter. Fairly cheap, maybe a bit noisy, but definitely something to play with and learn from
