- Feb 25, 2020
- 774
What? Oh my, mine don't change anything, I have 3 units but not the problem you say... I would have gone mad testing 1200 cells with the problem you say... maybe you have some other strange problem (?).Well sure you can swap out single cells but that would change the parameters of the the other cells when doing so! What a stupid design. If you swap out 1 cell then you have to reset the test (NOR test) for the rest of the cells and start all over with the rest of the cells!! So its either test 1 cell at a time or wait for all 4 to get done. That's dumb.
And I do keep an eye on timing, it always takes more or less the same time for similar cells.
There is a bug (Microsoft would call It a feature) that changes parameters if you quickly insert 4 cells in an empty unit: the settings of a cell influence previous cell but only in one direction (if I remember right It happens when quickly inserting cells from slot 1 to 4).
