MisterSmolFarm
- Mar 26, 2021
- 2
Hi everyone. As per thread title, I want to have some information regarding the setup and programming of the eSmart3 MPPT controller.
Background:
My dad bought a piece of land with a house a while ago, and the house came with big off-grid solar system, 3 Axpert 5Kva inverters in parallel, single phase and those very expensive Willard 2v cells making up 3 banks of 48V.
As he got someone professional in to look at this system, the tech told him that the batteries should be "equalized" to 60V once every month. But the Axpert inverters is not capable of charging the banks to the required 60V.
He invested into two eSmart3 MPPT charge controllers, thinking he can program them with a user interface to equalize the banks to 60V every month.
It seems to not be the case? after he contacted me, and I came for a visit to have a look at the newly installed MPPTs, because the guy who installed them, are not capable of programming them, he just installed it and left.
Now, since I am the only guy in the family who does this sort of things, I need to set up my dad in a way so that he can equalize charge the banks whenever he get full sun and when the inverters can be turned off/disconnected for a while.
Like an on-demand equalize charge.
Questions:
1. From what I have seen on the forum, I have to set the float voltages and such to what they need to be, as if it was a 12v system, dividing the values by 2/4 depending on the battery voltage (24 or 48, so for example 54V float voltage divided by 4 gives 13.5V) -> is this correct?
2. How do one set up the equalize stuff? Do you need to set the equalize voltage (again in 12v terms, 60v -> 15V) and set the equalize charge time to 0? The equalise time, is it in hours, minutes?
2.1 When does the equalize happen? Every first day of the month (according to the manual it seems) and it happens during the "Constant Voltage" charge stage?
2.2 What is the maximum time that you can set on the boost/equalize stage?
I have done protocol sniffing a while ago, (modbus, DLMS, the like) and integrated with the Axpert inverters using the Blynk platform (That is another story for another day), I figured it would not be so difficult to set up a sniffing session on one of those controllers, and use the MyGreen application to sniff the bytes and messages.
I will maybe link up an Arduino with an RS-485 module that will do the communications and configuration, so that my dad can just press the button, and the equalize charge is enabled/disabled.
Background:
Questions:
