Sleonard2649
- Aug 30, 2019
- 18
Do any of you know somebody familiar with ESP32 dev boards? I'm trying to get data from my 'Smart' Chinese BMS. I have the ESP32 but have no idea how to make this work.
I don't want to use bluetooth anymore, since it requires me to be in the shed with my batteries.Korishan said:With ESP32, you can't use BT and WiFi at the same time. The only way you could do this is to (rapidly) switch back and forth between connection types. This is a lot of overhead and will be prone to bugs and dropped packets on either radio.
CRaccani solution was portet from mega256 to esp8266 not esp32.Sleonard2649 said:.............I researched the following three github apps:
https://github.com/CRaccani/smart-BMS-NodeMCU
https://github.com/tomcosk/BMSBatteryMonitor
https://github.com/simat/BatteryMonitor
Presumably, if I get one of these running on my ESP32, ..........................CRaccini seems to have control capabilities which would be awesome!
I know that but you still have to change somecode and get different libraries for wifi its not an upload the sketch and your done scenario.daromer said:ESP8266 almost work out of the box on esp32. You dont need to do that big changes unless the libraries used only exist on one place. Then you have to redo some smaller code.
daromer said:With that Said... I dont see the reson just taking an esp8266 instead and you are Good to go
Nice! How's it working out, still good?
