I have two GTILs that i want to monitor locally and control some things based on the power in and out.
I have wired an XBee S1 set to transparent mode directly to the pcb pins that are labelled RS232.
Conveniently, there is a 3.4V power supply on one of the pins and can power the XBee directly. Its on the upper end of the XBee 3.4V max input power spec . Ive had it running with no issues for the past two weeks. The rx/tx lines are 3.3V/3.4V so they can also connect to the tx/rx of the XBee directly.
The diagonal pads next to the rs232 text is a jumper to 12V presumably to power line drivers
If we call pin 1 the one closest to the corner ofnthe board next to the cable going to the lcd display
1= Gnd
2=3.4VDC
4=txen for rs485 line driver
5= tx output
6=rx input
7 = 12VDC when the diagonal pads are jumpered
I dont know what the other lines do but these suffice for serial data. They are set to 9600-8-N1 and running modbus protocol
From what i see, It seems what is sent out of the wifi module is Just a couple of the registers.
Watts out appears to be a running average, not what is displayed on the lcd
Im trying to decipher the LCD cable frames next as that must have all of the data displayed on the lcd...which is what i need . Those also appear to be a modbus variation and 9600-8N1
1= Gnd
2=3.4VDC
5= tx output
6=rx input
