FERCSA said:I guess there is time for an update.
The second batch of the PCBs are here. I already started the assembly then I realized making a photo is a good idea. So not all of them included here.
So theoretically the whole system can handle around thousand cells. No one gonna build it I'm sure. In reality I limited around hundred, because the devboard's memory. It's still impressive, but if there any interest I willing to port it for ESP32. Beginning of this year when I started all of this, it was not available yet.
[img=300x224]http://www.fercsa.com/fcds/fercsa_p.../fcds/fercsa_discharger_module_revd.jpg[/img]
[img=300x224]http://www.fercsa.com/fcds/fercsa_d...fcds/fercsa_discharger_module_revd3.jpg[/img]
The firmware for my master module is kind of ready. If somebody started making my modules pls let me know then I can provide a beta firmware!
Otherwise looks like I have a few spare modules so if you want a kit or a complete build, it can be possible. Contact me for details.
My next video is coming, but my first video-shot was a disaster so I should make a new one. Please be patient I hate this kind of stuff.
NERDVille said:Have you thought of incorporating a DS18B20 one wire thermo-sensor?
mormor1971 said:Cool, would you be willing to sell me a few of the boards or even full kits that we could put together ourselves?
Grumplestiltskin said:Wow! This is truly awesome - a job very well done indeed.
The master and discharge modules look simple enough that I can do these, but what about the slave module? Is that something that could be built 'at home'?
I am looking towards a rather different form factor so I don't mind if it takes up more space...
Once again however, WOW!
FERCSA said:I started to gather all the necessary information from the topic and put together an all in one guide to help people.
It's very basic but I'll update it on regular basis if I found something useful.
https://www.fercsa.com/fcds/
And yes a lot of slave modules out in the wild already.
FERCSA said:Okay I think I just found a solution for the temperature sensor. I stepped back a little and rethink the design. What if I use the mosfet driver's pwn pin for switching the tp4056 enable pin to high and low?
So I added a little not gate inverter which turns on the tp4056 when the pwm zero, then switch off when the pwm signal reach a certain level. But this level is way too low to turn the mosfet on aka no load(discharge) at this point.
In reality it's works, I just tested. Any concern about this solution?
So after all I got a free pin which can be used for an analog ntc temperature sensor. This solution allows me to use 4 slot/cell with a 16 channel multiplexer which is great!
Currently the pinout for my discharger module: PWM, Temp, Battery voltage and current.
