Hello everybody!
Just few weeks ago my partner and I decided to renovate and move to the mobile house in Wicklow Mountains in Ireland. I would like to build hydro power on the small stream next to our house. I also have loads of battery cells from the bicycle batteries but it looks like the next step project.
What I was thinking to do is:
1. Build small hydro power with 1500w/ 24v permanet magnet generator:
its about 250euro
GENERATOR SPECIFICATION i1500G 24V
GENERATOR TYPE: Permanent magnet AC
Rated capacity: 1500W
ALTERNATOR BODY: Aluminum
Maximum current: 24V-55A
SYSTEM VOLTAGE: 24V
Then connect it to power Inverte:
VEVOR Hybrid Solar Inverter PWM 3KVA 2400W Pure Sine Wave Off Grid Power Inverter Charger 24V to 230V LCD Dispaly for Powering
about 250euro online.
I was thinking if I could connect this generator straight to the Inventor into battery input which is also 24V. Not sure if I need to have battery in this setup as the generator would give steady power.
About 1500w would be enough for fridge, lights, and lights in the house. We will have gaz/stove heating for water and heaters.
2. In next step I wanted to build the battery from the cells (I have about 20x 700wbatteries) I have and add solar power.
I'm just staring off with projects like this so any help and advice will be greatly appreciated!
Thank you!
Sławek
its about 250euro
SYSTEM VOLTAGE: 24V
Thank you!
Sławek
