- Jan 7, 2017
- 6,321
Below you find a list of Frequently Asked Questions. Please read them all and any references that may be linked. This will help a lot in the understanding and language used in this forum.
If there are any suggestions, tweaks, additions, etc that you think should be added, please add them here: FAQ Suggestions
Please note that clicking on the links below currently will open the link in a new tab. If you just want to scroll down through the questions, they are in numerical order according to the following order.
1. Definition of Battery, Pack, Module, Cell - What are they?
2. What is a serial connection (connection in series) and a parallel connection (connection in parallel)?
3. Electrical units / Electrical characteristics of a battery:
- What is V (Volt), A (Ampere), W (Watt), Ah (Amperehour) and Wh (Watthour)?
- What is capacity and energy?
- What is their relation to each other?
4. Why are 12V, 24V and 48V widely used defaults?
5. What lithium configuration do I use for 12V? 3S or 4S?
6. I see 14s80p or 7s16p, what does S and P stand for?
- What is xS, yP or xSyP with x and y being numeric digits?
- Is there a difference between 14s80p and 80p14s?
7. Charge Controllers and Solar Panel Specifications:
- What areMPPT and PWM solar charge controllersand what is the difference?
- What is better?
- What should I go for?
- How to read the specification of solar panels?[/b]
9. What size of wire / fuse wireshould I use?
10. What do I do if I want a 1kWh battery?
11. What's all this about the different chemistries?
12. Inverters:
- What type of inverter should I use?
- What is a hybrid/grid-tie inverter?
13. Inverter: What size inverter should I get?
14. Fuses:
- Do I need them?
- What kind/type to use?
- Where to use them?
15. Active Balancing vs Passive Balancing
Courtesy:
DarkRaven who put together the majority of this FAQ
- What is better?
12. Inverters:
14. Fuses:
- Do I need them?
Courtesy:
