Anybody got experience using these fusebox devices ? I'm on the search for some security options between my inverter and batteries. I'd love to get some circuit breakers, but I can't seem to find any decent ones. So I'm thinking of using these with 60A fuses.
My system is a 48V system, I don't plan on pulling more then 60A out of a single pack, since my BMS will cutoff the pack if this happens and while I'm at it, I want the option to expand for more packs in the future, so I was thinking of putting two of these things between the positive and negative terminals.
I also found these devices, which claim to be 12-48V, 200A DC / 1000A crank, but I don't know if I want to believe these numbers, they sound to good to be true. Anybody care to give me some advice here ...
A better solution might be getting fuse devices with terminal screws, so I can use cable eye terminals on my cables instead of trying to push them in the terminal block. I've got a high power compression tool, so I can easily crimp the eye terminals to the cable and the screw them to the fuses, but I don't seem to find fuses with screw terminals. They are all like this and I don't want a dangling cable when I have to replace the fuse.
