Good value 3500w constant 48v 'pure' sine inverter?
You can try it but you tend to get what you pay for and this is cheap and an unknown name. I don't have any special wisdom here - but I've tended to go with more common names such as MPP Solar, GroWatt, AIMS, and several others. Just to share a couple.... and I'm sure others will chime in with ones they recommend...
Here's a GroWatt - I know it's all in one but they are popular and (so far) seem OK. This one is 48vdc with 240vac outputat 5000w level https://shop.signaturesolar.us/products/5kw-48w-240vac-80a-off-grid-inverter-by-growatt for $900 This is less because there's no 120v whereas the ones below have both 240v/120v.
Here's MPP Solar - Again it's all in one but they are known/popular units. This one is 48vdc with 240v/120v at 5000w level https://www.batteryheavenpr.com/pro...-inverter-80a-dual-mppt-charger-free-shipping for $1395.
Here's an AIMS pure sine wave 48v@4000w 240v/120v charger/inverter - https://theinverterstore.com/produc...verter-charger-48-vdc-120-240-vac-50-or-60hz/ Its more in the $1400 range.
Me personally - I have ETL listed AIMS that have been running for 10,000hrs and counting ... :) The downside is that AIMS only has 'normal' efficiency (84% overall) and sometimes I wish I'd spent (perhaps) bigger $ on better efficiency such as MagnaSine.
powerhey
10k hours isn't bad!
The reason I'm window shopping is cause my 5048GK suddenly won't work even though there's no tell-tale signs (I'm in West Australia - using 240v ac 50 hz single phase.) It was only used for about 100 hours to test my battery. We've got mains, I just like to have back up power.
