Great Power ICR 18650 Cell Specifications
TheBatteries
Brand:Great Power
Model:ICR 18650
Capacity:2000mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
2000mA Standard
4000mA Maximum
Discharging:2.75V Cutoff
2000mA Standard
4000mA Maximum
Description:Orange Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.greatpowerbattery.com.hk...ng/Power Plus Spec (Li-ion 18650 2000mAh).pdf
Pictures:
507PowerWall
Are this brand and model do the work for powerwall ? or just for small projects ?
Just got 6 of them... hasnt tested or charged yet
Thanks in advance
CG from Panama
