Great Power ICR18650 2.2Ah-AT Cell Specifications
TheBatteries
Brand:Great Power
Model:ICR18650 2.2Ah-AT
Capacity:2200mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Orange Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Hi, the datasheet says:
Standart charge: CC/CV model, constant voltage4.2V, constant current0.2C?end current 0.01C
General charge: CC/CV model, constant voltage4.2V, constant current0.5C?end current0.01C
2200 * 0,2 = 440 mAh, is that it?
Witam
1. SCOPE This specification describes the related technical standard and requirements of the rechargeable Li-ion battery pack supplied by Great Power Battery (International) Co. Ltd. Battery packs produced with the cell will meet the specification. 2. BATTERY PACK SPECIFICATION ITEMS SPECIFICATION REMARK Model LIR 18650 Constant Voltage 3.7V Nominal 2200mAh Capability Minimal 2200mAh Cell Type LIR 18650 Dimensions ?18.0(+0.4)*64.5(0.6)mm Color / Weight 40(2)g 3. STANDARD TESTING CONDITIONS (No Load) ITEMS REGISTER Standard charge CC/CV model, constant voltage4.2V, constant current0.2C?end current 0.01C General charge. CC/CV model, constant voltage4.2V, constant current0.5C?end current0.01C Standard discharge Constant current 0.2C,end voltage3.0V General discharge Constant current 0.5C,end voltage 3.0V Charge 0 -- +45? Discharge -20? -- +60? One month -20? -- +55? Storage temperature Three months -20? -- +45? One year -5? -- +30? General temperature 20?5? Atmospheric pressure 86 -- 106Kpa Environment temperature Relative humidity 45% -- 85%
data taken from GREATPOWERBATTERY
