Had some more luck at the scrap yard. They had a whole pallet of power tool batteries, mostly Milwaukee and some DeWalt. I bought 13 heaping 5 gallon buckets full - that's about 500 pounds for 50$, pretty good at 10 cents a pound. About 10 percent rusty - those will get recycled again, another 10 percent just had cracked shells (warranty returns) so I'm in the process of swapping those out with other shells for normal use. Found approximately two dozen working Milwaukee packs ranging from 2Ah up to 12Ah. Most of the rest will be disassembled for the cells. Typically INR18650-25R Samsung cells in the 5Ah packs (the 4 Ah packs have 2amp cells, and the smaller packs are even less) - 21700 cells on some of the big packs.
Some of the 21700 form factor cells have a very thin sprayed on glue coating (like circuit boards have sometimes), it comes right off on some of the cells but on the others it is very stuck. I need to clean it off for charging, and was thinking maybe a scotch-brite pad for the ends? Anyone ever dealt with removing very thin clear spray on glue?
