Growatt 1500s
hermitdave
Just picked up Growatt 1500s inverter and in the installation manual it mention DIP stick config for different countries.
I can't seem to find UK on the list. UK grid network recommendations include G83 and G59.
Anyone have similar configuration with other inverter?
chuckp
hermitdave said:
Thank you @Sean
Ill try G59 first?
Hi bud
It relates to your PV size and connection type, most residential is under 4kWp and can be connected under G83. If over 4kWp then it would have been connected under G59 and required a DNO application approval, they would have come out and inspected the local grid power lines to confirm that it can handle your potential export.
That was what I had to do due to having a 7kWp system.
hermitdave
chuckp said:
hermitdave said:
Thank you @Sean
Ill try G59 first?
Hi bud
Many thanks
hermitdave
I was told that it should already be set but I will double check before installation.
