Headway 38120
Cujo6659
Should I charge my used 38120s before I build? Whats the best way? They don't make chargers for that. Can I just use my Imax or buck converter?
If you can emulate the charger's function with a CVCC buck converter, sure.
Must current limit properly + stop at controlled CV point properly. Should also disconnect when it reaches CV & current has dropped away.
You could also make socket adaptors, eg put a "blank" with wires in the regular & connect to a 38120 holder.
