daromer
Moderator
- Oct 8, 2016
- 5,665
Yeah unfortunately thats most likely the most common way. I could think of using heated elements under with water but then isolate the elements. Then you can use the heat during summer to heat water. But once again you then should/need to leverage the angle so the snow glides off. . Or thinner layers
I did some serious look at heating water under/cooling the elements but at same time then i would have needed more costly devices. So i bought a broom instead
