Yes, take you time, meanwhile you could start buying all that little stuff you need to manage you project.
I started off with a few things and then I ended up buying a LOAD of things online (I love AliExpress for my prototyping stuff), these were my first buyings:
- 18650 battery supports;
- a better tester for DC voltage/current (for now I bought a 20$ RichMeters RM303 with 0.05% accuracy on DC voltage, what I need the most, one day a lovely Fluke may be on my desk!);
- a couple of variable voltage boards (DC-DC converters) for quick tests/charging/powering up some or another device;
- connectors, xh2.54 for low current and xt30/xt60/else for higher currents;
- wires, AWG26 for little currents, AWG18 for my 1 or 2 amps, etc;
- a support for soldering and new soldering tips, flux and different diameter tin.
All for a bunch of $ online...
yes, I want to learn chinese!
Here, I'll show my last-night-project, it's the base for something bigger. I will share it in the Project section of the forum soon:
Bottom-Left: my Arduino boards collects data from sensors around the house (water level in the tank, temperature, humidity, and soon voltages/current from solar and batteries); and sends data out to the web using an ESP8266 WiFi.
Top: a smaller board, an ATTINY85 collecting temperature and humidity and sending it to the Arduino board.
Right: my small battery box with a voltage display and a switch to display the current value.
Love it!
