thank you very much, i will test them and post my results11.1/3.7=3 6600mAh/3=2200mAh about all I can figure out her is a thread on unknown ASO cells
Later floydUnknown ASO/SZN Cell Specifications
Warning: The information in this thread was obtained from various sources on the Internet, including any datasheets linked below, and is provided for reference only. It is not guaranteed to be accurate. To prevent fire or personal injury, never charge or discharge a cell before verifying the...secondlifestorage.com
OK - assuming 2200mah level cell, then they are testing at 1700mah/2200mah = 77% of original capacity. These are useable if you're OK with this level and the IR remains low.good evening, as said I give the results of the batteries,
min 1650 mah
avg 1700 mah
max 1750 mah
my tester is not very reliable, so I add 10% at the end of each test and I rounded the mah (ex 1714 -> 1700) good evening
yes, I used 5 batteries at 1700mah for screwdriver / drill (5s bms 50A 21v at 4.2v / cell), I disassembled an entire laptop then reassemble then disassemble (hs motherboard) and my batteries were at 4v, the batteries were not fully charged before use, but lack of power noticed when I have to force hard enough, low voltage cut I think.OK - assuming 2200mah level cell, then they are testing at 1700mah/2200mah = 77% of original capacity. These are useable if you're OK with this level and the IR remains low.
