Redpacket said:
If the OP follows the flow chart I posted a few back they'll be fine (credit to daromer).
No, because following that flowchart you posted would have likely resulted in the same explosion that I linked. It gives the reader no clue of how to properly perform the precharge phase, as I explained at length above. Precharging is one of the riskiest parts of Li-ion use. It is irresponsible not to explicitly mention this. In case you forgot, the chart says only this on precharging "if not above 1V then put in current manually 3V, 200ma". That's surely the most dangerous description of precharging that I've encountered in a few decades time.
Generally (not only for precharge), competently designed Li-ion chargers will trigger a safety exception if any charge phase takes too long or if it exceeds a temperature limit, e.g. see the "cut time" and "cut temp" settings on the SkyRC MC3000, and similar settings on quality RC hobby chargers - which are always enabled by default (and disabled at your own risk).
