Help a new member wire BMS properly
RV4lifeCanada
Hello, I bought four 4 packs of 3.2v 100ah batteries from the following website:
https://batteryhookup.com/products/new-battery-hookup-lifep04-32650-3-2v-5000mah-cells-1
So essentially I have 16 packs of 3.2v 100ah batteries and 4 100ah bms. They are made from 32650 lithium cells, brand new. The 4 pack bundle was meant to wire 4 packs of 3.2v batteries into series to get 12 volt 100ah. Each 4 pack comes with a 100ah BMS.
I do know how to wire them in series to get 12 volts. But I do not know how to wire the BMS. I emailed support and here is what they said:
Hi!
Sorry we cannot offer any technical advice at the moment
The B- wires go to your battery main negative, the C- goes to your charger
Can someone clarify the above? So all B- goes to negative, but what about the positive?
Also, is there a way to utilize 4 bms on one single 12 volt battery 400ah?
cak
Here is a diagram, many BMS come with a simple schematic like this. The positive goes directly to the load ideally via a fuse or breaker. This pic assumes you are putting all 16 in series for a 48VDC pack if you are only doing a 12VDC pack then just parallel 4 together + to + and - to - is parallel. The BMS wires can be thin but make sure the main wires are thick enough to handle the amps you plan to put through them, that's also where the fuse/breaker protects the wire if properly sized.
