high amp tp4056
Yeah, they did, and it's absolutely rubbish, as Adam mentions in the video. Well, in this one where does an update:
The problem is there's to much variance between the chips and the resistors to be done alone. Maybe if they added some caps or something to smooth it out and make them all read the same, it'd be ok.
I think it works ok for the price.
In the first stage of charging it works good.
in the final stage is when the the lower tolerance chips drop out.
I hooked up 2 tp4056 in parallel onto one battery, They cut in and out and don't work correctly, one is feeding the other voltage and it thinks its done charging.
You would have to build your own to make it work.
bucks for 500w cheapest hobby I have found yet.
My search still continues for a super high amp charger for CHEAP
I'm not looking for a finish charger.
I am looking for just constant current
4s at 1000watts and just stop when it gets to a voltage.
The reason I want this.
My install is in a rv, if I run out of battery and solar isn't keeping up how do I run the 12v lights?
I just answered my question.
I'm not looking for a charger I'm looking for a backup 12v system.
http://www.ebay.com/itm/PowerMax-RV...ash=item1a23d663db:g:-w0AAOSw241Yd79q&vxp=mtr
Use that hooked to the generator to supply 12v to the rv.
Will the float on the charger hurt the lithium pack ?
There have been many who have stated that float charging lithium is bad. Though, I'm not sure why or how. I'm sure someone will chime in on that.
I have only hear of a lead acid charger on lipo 3.2v batteries and the float is bad for them.
I have never heard of one being used on li-co since the voltage is so much higher.
Here's an answer:
https://www.electronicsweekly.com/market-sectors/power/float-charging-lithium-ion-cells-2006-02/
Whereas lead-acid, NiCd and NiMH cells can, and are, designed to be able to convert some over-charge current into heat by a process called recombination; Li-ion cells cannot. Any current forced into a fully-charged Li-ion damages it.
[size=medium]At minimum this reduces cell life. At the extreme maximum some unprotected cells have been known to burst and catch fire. Protection against failed voltage or current regulation should always be present in a Li-ion or lithium polymer charging scheme.
[/size]
In float charging, current entry beyond full charge is prevented by choosing a charge voltage less than or equal to the voltage naturally produced by the cell at full charge which depends on the cells exact electrochemistry and temperature.
[size=medium]It is all related to battery voltage, says Robin Cloke, UK MD of GP Batteries. As a general rule of thumb, if you choose around 4.0V it is fairly safe for the cell.
[size=medium]Specifically for his cells, Cloke says: 4.2V is actually what some people do, but if you are going to leave on the voltage, back it off to 4.1V.
[size=medium]Something to be noted here is that there are trade-offs to be made between the voltage chosen, cell chemistry, ambient temperature and cell life.
It is very much on voltage and temperature, says Mike Lain, a battery scientist at the UKs ABSL Power Solutions. We have done some tests charging cells at 4.2V. At 20C there is steady capacity loss, and after two years 80 per cent of capacity is retained. At 60C there is very rapid capacity loss. Dont even think about it.[/size][/size][/size]
This article continues on with that it is possible to float charge, however, you need balancing in place. You also don't want to be near the top end of the voltage, so 4.1 is what he mentioned above. Also, as long as temps are low, then it may not hurt the cells.
However, that is only one study. It does rule slightly in your view of floating. But I'd still take it with a grain of salt.
I think float charging is bad for the cell because they weren't designed to keep being charged at the top end of there voltages. All the lithium chargers will only kick in once the voltage drops to like 4V or 3.9V, maybe 3.8V, then they start the charge process. This is done for good reason and for longevity of the cells.
As mentioned in the above article, float charging could be done, so as long as certain settings are configured in the charger (a ups unit was the example) and balancing is done on the cells to ensure they are operating correctly.
Thanks.
It will work perfectly for me.
don't think battery charger, think more current and voltage supply.
where the battery charger voltage gets to the max battery voltage.
I need this in for emergency back up.
Powered by the generator.
so any charging this way i will be around it and when I'm done i will shut the generator off.
