@powertrack,
I've just checked your project thread (with Google translate), and I'm impressed. That is real hardware with all that power electronics and big Leaf battery. I was thinking about such an approach but then decide to go Goodwe hybrid inverter. It's a pretty good device and indeed has all features for the HV energy storage system.
I agree with you a CAN Converter/Gateway is a core component in these projects. The current solution (Raspberry Pi) is somewhat too complicated, and I'm not sure about its long term reliability. But it's making hacking and debugging a lot easier. I'm planning to make an embedded device (MCU-based) and replace it, but this will take some time.
BYD HV System is an intriguing device supported by many inverters. I have to check how Fronius Symo talks to it, whether CAN bus or MODBUS.
@Cheap 4-life,
I took the battery from a local dealer of used Chevy Volt cars. (located in Bulgaria, Europe). It's from a 2012 car and was staying unused for a long time. I've checked it and found two dead cells (zero voltage). Other cells showed a capacity of around 38.5Ah from the original 45Ah.
I've tested cells with iCharger B208 according to datasheet limits from 4.15V to 3.0V. So the numbers that I gave in my previous post are real-life data, not estimate. Now I'm using 94 of 96 cells, which equals the maximum available capacity of 13.4kWh. Let say that I go with 80% DOD that is 10,7kWh usable capacity from the inverter.
@Cheap 4-life,
