Highstar ISR18650-1300 Cell Specifications
TheBatteries
Brand:Highstar
Model:ISR18650-1300
Capacity:1300mAh Rated
Voltage:3.70V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Blue Cell Wrapper
Grey (Dark) Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Hey I have come across some Highstar ISR18650-1300 Cells that have a grey cell wrapper and a red insulator they came out of a 18 volt drill battery pack from harbor freight. I have included a picture just to help expand our knowledge base of 18650 cells that are out there to be recycled and reused.
Photo of the red insulator that is on the grey wrapped Highstar ISR18650-1300
Different Highstar being used in some Ryobi 40V packs. Found these in OP40404 from 2021. ISR18650-2000. INR19/66 3.7V 7.4Wh Orange wrapper, black insulator.
I know that the IR is on that chart, it states 20 milliohm and max charge voltage is 4.2V other than that I didn't find anything. I also found some contact details of the manufacturer and asked for a datasheet, so i'll get back with that if they send me one.
Hey guys, Highstar replied and provided a Datasheet for these cells, the Datasheet has information on absolutely everything!😁
  • ISR18650-1300大配组通用技术规格书-486-2019.pdf
I got a set of these in an 18v Ryobi High Output pack as well.
I have found some purple with black rings - Highstar ISR18650-2500 - INR19/66 (from a cordless vacuum cleaner).
I have attached the datasheet for these batteries.
  • 6-871892-Orange-ISR-18650-2500mAh-8c.pdf
