ocaluptous said:here is a datasheet for a similar cell.mike said:You would have to check the datasheet from the manufacturer. Those cells are your typical Chinese special. Unfortunately, you probably won't find a datasheet and I wouldn't even use them.
If you have a minute to take pictures, we can at least get them added to the Cell Database.
seems ok on this end.Korishan said:ocaluptous said:here is a datasheet for a similar cell.mike said:You would have to check the datasheet from the manufacturer. Those cells are your typical Chinese special. Unfortunately, you probably won't find a datasheet and I wouldn't even use them.
I think you forgot to add the file. ???
Yeah, this is fine. Being high current cells doesn't mean they have to run at high current the whole time. Shared with all the other cells, they'll see very little current draw as long as all connections to the parallel group are equally connected to the bus and you aren't trying to pull 100+A from the packcan I put one cell in each of the 80p packs
Agreed just use them. Spread them out, because they have much lower IR than the usual cells you will get from laptops/modems and such.Thanks Korishan.
