Home Battery in belgium
Nicsal
Hey,
I started creating my powerwall 2 years ago.
Now that we only get 0.04 euros per kWh injected to grid from surplus solar panels power.
Two years ago I bought my first Samsung INR18650-29E 2900mAh E6 - 8.25A - Refurbished cells,
these come from bicycle batteries that were ridden because there were errors in them, Nkon.nl has tested them.
on some were no spot marks.
for in 14s100p
A year ago I expanded this with another 14s100p
new cells from Nkon.nl,
BG INR18650-26R 2600mAh
a few months ago i did another out brawl of 14s200p,
sony 2150mAh
purchased at bva-auctions.com
these cells have been tested by EnergyCells
there were some problems with the delivery.
but everything to a good end.
now i am working on another 14s200p
with cells purchased at bva-auctions.com
refunt from BVA for the cells that did not come.
more random cells,
samsung 2900mAh
samsung 3500mAh
sony 2150mAh
lg 3500mAh
panasonic 2900mAh
on a delta grid 3x230V
2 victron multiplus II 3000VA parallel
random chargers +-10kW vermogen
the chargers are turned on automatically by a current relay that measures the current from the grid tie inverters
Nice work and thanks for sharing :)
Sounds like you don't have solar panels? And you're storing energy at low prices and then consuming your battery energy when grid prices are hi?
Could you explain a bit more? (it sounds interesting).
Nicsal
I forgot to report.
I have:
40x 195W solar panels grid tie inverter 2x platinum 4600W
15x 275W solar panels grid tie inverter SMA 5000W, current sensor - + 5A switches 1kW charger and current sensor - + 15A switches 4kW charger
18x 310W solar panels grid tie inverter SMA 7000W, current sensor - + 5A switches 1kW charger and current sensor - + 10A switches 3kW charger
and my energy prices are:
night and weekend 0.20euro
day 0.25euro
in the winter I charge the battery at night, for the day when there is not much sun to use.
Nicsal
BMS = Smart Bluetooth 7S-20S CELL Lifepo4 li-ion Battery protection Board BMS 320A 14S
Chargers = Emerson R48-2900
and some 24v1000w power supplies with stepup cc -cv
two grid tie 1000W inverter (working voltage 25-45v) with step down cc-cv 48V to 32V for discharge
J_Mack58
Man that is a nice setup you have. I'm looking to get some electrical cabinets with the upper and lower ventilation when the plant
I work at closes. They house our Allen Bradley Powerflex drives right now. When we close (in about a year) all the good robust electrical
gear is free game.
Nicsal
Update: Today expanded with another 2800 cells and a total of 8400 cells
calculated that it would be a - + 66kWh in total
here you can find my design of the voltmeter for the 18650 cell
https://www.thingiverse.com/thing:3786188
Congratulations! Its a lot of fun to get a new battery online after all the work creating it.
Will you continue to expand?
Nicsal
No, I'm not going to expand for the time being.
(here are some old photos)
